The Single Click generators at http://uvnc.com/downloads/single-click/ ... loads.html do not appear to be working.
After filling in the UserID, Password, and Upload File, clicking 'Upload' results in a new page with a new instance of the form, but with no download link for the generated executable. The UserID and Password fields are filled in. The 'Upload file' field is empty. Selecting a zip file and clicking upload again has the same result.
Zip files were created with 7-zip in zip format. In my tests, all files but helpdesk.txt were original. Tests with zip files that I created using known good helpdesk.txt files and the original helpdesk.txt file failed in the same way. Zip files that had been used successfully by a co-worker last fall failed in the same way.
Google Chrome, Firefox, and Internet Explorer 11 all failed in the same way. On Chrome, all UVNC sites are whitelisted in adblock and ghostery. No plugins were active on Firefox or IE.
All tested uploaders failed in the same way, including:
upload9.pl (Experimental June 2015 win8 win10)
upload5.pl (Same as pevious, but exe request UAC on start.)
upload4.pl (UltraVncSC update Feb 2015)
Has anyone else seen this problem, or recently generated a Single Click executable successfully?
Thank you,
John
SC Generator not working?
Re: SC Generator not working?
People are still generating exe there a 50 exe created 1/18
Are you using the fixed foo/foobar as user and password.
I have the same problem on all submit forms. can not generate exe even with my old zip files. Seems like nothing happens after a minute's wait, same screen, with the submit form filled, no redirection. I tried to switch off timeout in Firefox - no luck
support1 down
The check to see if it was working initiated the MS updates... and he auto rebooted.
restarted apps
restarted apps
I have the same problem.
Someone solve?
Someone solve?
