we are using vnc for some desktop monitoring in view only mode. When the "viewer" connects the end user loses the ability to cut and paste.
anyone have a fox for this?
Daniel
Clipboard not working
Re: Clipboard not working
Can repeat it. Tested view only and full.
I guess it only exist in combination with another software that also use the clipboard chain.
Unless we are able to repeat it, a fix is not possible.
Any special clipboard option Start > Settings > System > Clipboard.
For Windows >= Vista, you could use AddClipboardFormatListener / WM_CLIPBOARDUPDATE which is simpler and does not depend upon the old flakey Clipboard listener chain anymore.
https://docs.microsoft.com/en-us/window ... atlistener
