Send Ctl Alt Del no effect to login
diezwei
Post by diezwei »
no effect by klick on the button send Ctl Alt Del to login on Windows. This ist only on clients with a new Windows installation.
Some clients works fine.
We are using Windows 10 1909 and Ultravnc 1.2.50. This problem was also with version 1.2.23.
Is there a solution to fix this?
Greathing
Ralf Reich
Re: Send Ctl Alt Del no effect to login
Running as admin or service ?
diezwei
Post by diezwei »
Thanks for replay.
VNC runns as service
To enable Software Secure Attention Sequence:
Open the Local Group Policy Editor on the agent machine:
Press
+ r to open the run dialog
type gpedit.msc and press Enter.
Expand Computer Configuration > Administrative Templates > Windows Components
Select Windows Logon Options.
Double-click Disable or enable software Secure Attention Sequence.
Select Enabled.
Select Services from the drop down list in the bottom left pane.
Click OK.
diezwei
Post by diezwei »
Thank you for the suggetion. I want to test it, if I have a computer with this error.
This error is not on all computers.
