I was looking at the Nat 2 Nat Helper http://www.uvnc.com/addons/nat2nat.html.
Eventually I tracked down the documentation that the NH (Nat Helper is run by uVNC - same ID as the forum member registration.
Is this Nat Helper service active?
NSC and NVC did not appear to find the server (status stayed on red), the Debug window remaining open and cycling between Sending member info and Timeout.
Thanks.
NAT 2 NAT
Re: NAT 2 NAT
This is some test software from 2007...
Replaced by uvnc2me.com
Re: NAT 2 NAT
Is this service / server still running? I get only "Sending member info" and then "Timeout"
Thank you!
Thank you!
